Content key к Bentley eBahn Audi TT Coupe, TT Roadster
Сообщение autocd » Ср янв 30, 2008 3:19 pm
Jake I not need your Serial, I need Installation Code only
autocd
Site Admin
Сообщение Jake » Ср янв 30, 2008 10:55 pm
We say:
"A picture is worth a thousand words"
Maybe this will help the next guy to not make the same mistake that I did.
I suppose that everytime I change laptops, I am going to have to do this?
Jake
Сообщение autocd » Чт янв 31, 2008 7:14 am
Jake
907b-e90c-bb9b-b698-3a20-ce41-baca-bde4
autocd
Site Admin
Сообщение zippyo » Чт янв 31, 2008 6:02 pm
SUX to be ignored! thought it was cuz i speak no russian, but guess that is not the case. I can try in hungarian, but doubt it'll change a thing. At least a reply would be nice since all i asked for was help not just moochin' for that ALLMIGHTY keygenned number.
C'mon guys have a nice(r) day
zip
zippyo
Сообщение Jake » Чт янв 31, 2008 8:13 pm
Autocd
That worked. Thank you.
Zippyo
I never deleted demo2d.dll or vregistry.dll to make this work. If this is part of a demo version, uninstall usually works for most commercial applications.
I don't think that the serial number plays a part in unlocking the software.
Try 1234-1234-1234-1234.
Your unique Installation Code is generated by the software and some part of your computer identity.
You need ebahn version 2.5.
93-99 golf jetta cabrio, Installation Code (like my .jpg above) and Autocd to get a new Content Key.
You said that you don't need this number though, so I assume that your iso contains this. After install and unlocking, I found a new file made with the first 16 characters of my generated content key:
..BentleyPubs\eBahn\lic\907be90cbb9bb698.ebl
Maybe check this.
Sometimes translations can be viewed as insulting even though it is not intended in the original language. "Moochin" or moocher is condescending enough in English; I can't expect it to be better in Russian.
Jake
Сообщение zippyo » Чт янв 31, 2008 10:47 pm
Thank you for taking the time to reply Jake!
xxxx-xxxx-xxxx-xxxx-xxxx-xxxx is the format for SERIAL for v3.0
did a quick search for 2.5 but I couldn't find it. the new package I D/L-ed from bentleypub is packaged with 3.0.x
demo2d and vregistry dll's I dumped from memory with Olly, as they are part of the packaged executable. Seen refs to but couldn't yet get to ts_osd.dll or the exe for the reader. found exe in memory but the headers are a little confusing when mangled, not a lot of info circulating on the issue since the older thinstalls 2.5xx, this is packed up with 2.544(?).
was hoping that someone can point me in the right direction to get to the keygenning or checking routine. "moochin'" was the generalization I made based on a lot of peepz just want it all with no work done on their behalf.
I want to learn and dig for answers but couldn't progress further without help.
Sorry if I offended anyone! was not the intent
any help is appreciated if shared
just an another confused amateur code bugger:
zip(Peter)
zippyo
Сообщение Jake » Пт фев 01, 2008 12:47 am
As far as I know, Autocd is looking for the 3.0 keygen as well. If you find it, post the information here.
Version 2.544 may be ok. You will only know for sure by running the application. I believe that version 2.5r01sp0003 is the last.
This thread is not the appropriate place for information on version 3.0. I would assume that version 3.0 has an entirely different method for encryption than 2.5.
Jake
Сообщение termalgin » Вс мар 09, 2008 1:21 am
Здравствуйте!
eBahn Reader 2.5r01
Volkswagen Vanagon 1992-2003 Vw Bus t4
Installation Code: 3544-9999-cc8a-dec4
Content Key: ???
Приветствия и спасибо для вашей хорошей работы
termalgin
Сообщение autocd » Вс мар 09, 2008 7:33 am
termalgin
8fdc-fe79-9464-344d-823b-8a8c-191a-8ba0
autocd
Site Admin
Сообщение tor77 » Ср мар 12, 2008 9:59 pm
Привет !
Помогите,пожалуйста, с ключиком
eBahn Reader 2.5r01
Audi TT
Installation Code: 7256-ab31-00f4-8fdb
Спасибо.
tor77
Сообщение autocd » Чт мар 13, 2008 6:36 am
tor77
2edf-ead2-a211-60fc-63b4-8e9a-b285-e46e
autocd
Site Admin
Сообщение Seacar24 » Пт мар 28, 2008 12:08 am
Hi autocd,
I see you do some great work in here.
I need a key for Volkswagen Vanagon 1992-2003 Vw Bus t4.
eBahn Reader Version 2.5r01
Installation Code: : 6ec0-ced0-4391-a3c6
Can you please help?
Thanks in advance, Seacar24
Seacar24
Сообщение autocd » Пт мар 28, 2008 10:33 am
Seacar24
3a0e-48db-9e66-f878-4caf-e993-5785-0b3b
autocd
Site Admin
Сообщение mach1 » Вс мар 30, 2008 3:24 am
Hi Autocd,
Please, i need a key for Audi A4 2001-2004 (B6),
Installation Code: : 0214-c328-8b20-329f
Thanks in advance, mach1
mach1
Сообщение Seacar24 » Сб апр 19, 2008 1:09 am
Hi again autocd,
I had to reinstall the programs on a new motherboard, and it seems I need a new content key. Can you help?
Installation Code: : dc63-aca1-dc17-a78f
Seacar24
