Workshop 2006 4 q нет соединения с б.данных
Сообщение Павел1 » Пт май 23, 2008 12:54 pm
Установил пр-му ,при запуске выдает ряд сообщений:
Repair DatabaseFile
No permission to delete bad file C\Documents and Settings\
Павел\Local Settings\Application Data\vvddata.wrt
потом
Connect failed
SQLSTATE=S1000
[Sybase][ODBC Driver][Adaptive Server Anywhere]General error:
Beyond end-of-file
после этого она открывается но на все значках в меню знак ,кирпич,.У каждой надписи у меню приписано T(@
в панели задач открывается VVD SERVER:
Failed to initialize NT performance monitor data area
Sybase Adaptive Server Anywhere Database Engine Version 6.0.3.3094This software contains confidential and trade secret information of
Sybase, Inc. Use, duplication or disclosure of the software and
documentation by the U.S. Government is subject to restrictions set forth
in a license agreement between the Government and Sybase, Inc. or other
written agreement specifying the Government's rights to use the software
and any applicable FAR provisions, for example, FAR 52.227-19.
Copyright 1989-1999 Sybase, Inc. All rights reserved.
All unpublished rights reserved.
Sybase, Inc. 6475 Christie Avenue, Emeryville, CA 94608, USA
6144K of memory used for caching
Using a maximum page size of 4096 bytes
Starting database "fidrem" (C:\Documents and Settings\All Users\Application Data\WorkshopCD\Data\fidrem.db) at Mon May 19 2008 16:44
Database recovery in progress
Last checkpoint at Mon May 19 2008 16:30
Checkpoint log...
Rollback log...
Checkpointing...
Starting checkpoint of "fidrem" (fidrem.db) at Mon May 19 2008 16:44
Finished checkpoint of "fidrem" (fidrem.db) at Mon May 19 2008 16:44
Recovery complete
Database "fidrem" (fidrem.db) started at Mon May 19 2008 16:44
Database server started at Mon May 19 2008 16:44
Now accepting requests
Starting database "vvddata" (C:\Documents and Settings\Павел\Local Settings\Application Data\vvddata.wrt) at Mon May 19 2008 16:44
Fatal error: beyond EOF
Disconnecting shared memory client, process id not found
Ставил на ХР и в совм-ти с 98-- ничего
В про-ме есть тест на сое-е с б.д. Пишет нет сое-я
Поможите кто может
Павел1
