NEOPLAN
Сообщение autocd » Чт дек 28, 2006 12:31 pm
NEOPLAN MANUAL SWING PLUG DOOR TYPE: SPP
Introduction
This manual will inform you about the installation of your Ventura door system. You learn how to recognise components and to select these components and built them together to achieve a good working and safe door system. We provide you drawings, adjustment values en checkpoints.
This manual is ordered chronologically. First we start with a list of components and a description of the door system. After checking the availability of the components you learn how to install the system step by step. The next procedure is the adjustment of the system. Finally you have to be convinced that the operation of the door system is correct. Therefore you will find a checklist in this manual.
There is the possibility to follow an installation training. More information you will find later in this manual.
autocd
Site Admin
  • Сейчас этот форум просматривают: Google [Bot] и гости: 1
