COMAND UNLOCK V2.0 CONSOLE
Сообщение arrivalus » Пт май 04, 2007 12:13 pm
The following cars are able to be unlocked with this manual:
CLS - W219 E CLASS - W211 SLK - R171 S CLASS W220 (WIDESCREEN) SL R230 (WIDESCREEN)
This guide will allow you to enable the following features
View the TV while the car is moving
Play multi-regional disks and DVDRW
Enable mp3 playback
Modify other hidden features
Note: Please follow this guide carefully and you will be able to open these features within minutes. We hold no responsibility for human error these codes work for the right console listed above. We also like to point out that it is illegal to enable the TV whilst the car is in motion and therefore advice you not to activate this feature. If you go ahead then it’s your responsibility.
Copyright © 2006 Stuart Criddle All Rights Reserved.
This work is registered with the UK Copyright Service: Reg. No:255604
INSRUCTIONS
1 Press the audio button to enter audio mode
2 To enter the engineering mode press the 1 mute, 2 phone and
3 serv buttons and hold for apx 45 seconds until you see a message saying “welcome to engineering mode”.
To enter the secret menu press and hold * button then the # followed by the < button and hold them all simultaneously.
To access the video in motion menu press the button next to Dr.Dist.
6
Using the arrow keys deactivate all of settings with the OK button. Your screen should now look like the photo below –
Press the back button to go back to the main menu
7
To access the MP3 enabling menu press the button next to Backd.
Using the arrow keys, highlight the MP3 feature and enable it using the OK button.
Now go back to the main menu using the back button.
8
To access the DVD region menu, press the button next to regcod.
Using the arrow keys, highlight the region free setting and enable it using the ok button.
To activate the settings press back then end and switch the command console off then back on again.
All setting may be activated and de-activated as many times as you want.
arrivalus
Сообщение Крымчанин » Пт май 04, 2007 12:16 pm
а это уже интересно
Сообщение arrivalus » Пт май 04, 2007 12:30 pm
у меня узкая магнитола
на широкой должно работать не могу на узкую найти походу там Comand 1
Добавлено спустя 29 секунд:
у когонить это сработало ?
Добавлено спустя 6 минут 48 секунд:
в картинках
http://home.online.no/~alla-ra/artimage ... des_k_.pdf
Добавлено спустя 3 минуты 46 секунд:
более подробно
http://www.freenetpages.co.uk/hp/towerp ... enusv2.pdf
arrivalus
Сообщение Electric » Пт май 04, 2007 12:54 pm
Это для коммандов, а у тебя вроде как Аудио 50
Electric
Сообщение arrivalus » Пт май 04, 2007 1:18 pm
угу какая жалость :)
arrivalus
Сообщение Roman » Пт май 04, 2007 1:25 pm
Блин, а для новых BMW такое есть ???
Roman
Сообщение Electric » Ср май 23, 2007 12:50 pm
Новые Комманды, уже русские с завода, кому нибудь удалось загнать
в инженерку?
Electric
Сообщение Vadim AA » Ср май 23, 2007 12:54 pm
На двух 220 не получилось попасть в серв.меню .
Vadim AA
Сообщение Electric » Ср май 23, 2007 2:29 pm
220 с MOST(с сентября 2003) входят без проблем
Electric
Сообщение Крымчанин » Сб май 26, 2007 12:02 pm
Electric писал(а):220 с MOST(с сентября 2003) входят без проблем
шото я пыхте и нифига не зашло
мож шото не так нажимал ???
Сообщение Vadim AA » Сб май 26, 2007 10:16 pm
211 - не получилось.
Vadim AA
Сообщение Крымчанин » Пн май 28, 2007 10:13 am
Vadim AA писал(а):211 - не получилось.
а вот у меня в 211 легко заходит
Сообщение Electric » Вт май 29, 2007 9:52 am
работает... при условии что 211 дорестайловый
Electric
Сообщение Vadim AA » Вт май 29, 2007 10:03 am
Значит мне не везёт.
p.s. старухой проще
Vadim AA
Сообщение Anturage » Ср май 30, 2007 10:02 am
Electric писал(а):работает... при условии что 211 дорестайловый
От версии софта зависит.
В новых версиях опция либо отключена либо переведена на другие комбинации кнопок. Уж очень сильно инфа разошлась по миру :lol:
Странно что никто не знал... В штатах уже давно баян :smile:
Anturage
