ключ на S6 97года С4
Сообщение Anntonn » Вт фев 06, 2007 5:53 pm
Подскажите пожалуйста как запрограмировать штатный ключ на центральный замок? Ключ с заводской сигнализацией. Заранее благодарен. Антон-Могилев.
Anntonn
Сообщение deusex » Вт фев 06, 2007 6:24 pm
NOTE: A maximum of 4 keys can be programmed.
As memory positions of existing keys are unlikely to be known: Obtain and program all keys.
Switch ignition ON.
NOTE: Use key that is not fitted with remote control.
Manually lock vehicle using key.
Complete the following within 30 seconds, one key at a time:
Point key to be programmed at receiver. Located in 'B' pillar on both sides.
Within 5 seconds press lock/unlock button on each key 1-4 times at intervals of at least 1 second:
Once for memory position 1 (first key).
Twice for memory position 2 (second key).
Three times for memory position 3 (third key).
Four times for memory position 4 (fourth key).
Alarm horn sounds each time button is pressed, to indicate signal received.
After programming last key, wait 5 seconds.
Press lock/unlock button once to confirm programming.
Vehicle unlocks. Programming mode deactivated.
deusex
