Audi A4 проблема с ключем
Сообщение wenas » Чт май 05, 2005 12:12 am
Все дружно берем словарик и переводим...
Self-diagnosis of central locking system
Matching or deleting vehicle key for radio remote control
The vehicle is supplied with two remote keys.
You must match radio remote control ignition keys which are new or have not yet been matched using the central locking control unit -J429.
The vehicle keys must also be adapted to immobiliser control electronics.
=> Electrical System; Repair group 01; Immobiliser Self-diagnosis - Fixed code
If a fault from 00955 to 00958 is displayed, the remote keys must be rematched.
Matching procedure for new remote keys
‒ Switch on the ignition (using additional key).
‒ Check how many keys have already been matched in measured value block 003 => Page 01-103.
→ Indicated on display: Read measured value block 3 ⇒
0 0001 0 0000
Display zone 2 shows how many remote keys have been matched and in which memory positions (1x in position 1 in example shown).
‒ Lock vehicle from outside with the key to be adapted by way of the driver's lock door.
‒ Within 5 seconds press "unlock" key of remote key until next memory position is reached (2x in example).
Each time the button is pressed the hazard lights will flash to confirm.
‒ Wait 5 seconds.
‒ Now press the "unlock" key again to confirm the matching process.
This vehicle key is now saved and the central locking must unlock.
‒ Switch off ignition and remove ignition key.
‒ Check function of new remote key.
‒ Check display zone 2 measured value block 003. It must now contain an additional "1" (in example: 0011).
→ Display zone 2 shows how many radio remote control keys have been matched and in which memory positions (2x in positions 2 and 1 in example shown). Read measured value block 3 ⇒
0 0011 0 0000
Notes:
◆ Repeat matching process for any further keys. Ignition must always be switched off following storage.
◆ Make sure new keys are always matched to vacant memory positions. If use is made of occupied memory positions (can be seen from "1") the radio key already matched for this memory position will no longer function.
Re-matching procedure for existing remote keys
Note:
This procedure must be performed after changing the batteries in remote keys, or if the fault reader displays fault codes 00955 to 00958.
‒ Press key on remote key.
If vehicle is neither locked nor unlocked:
‒ Lock and unlock vehicle within 30 seconds by way of driver's door lock.
‒ Then check function of re-matched remote key.
If vehicle is still not locked or unlocked, key must be re-matched. Match remote key =>Page 01-106.
Procedure for erasing memory positions
Note:
It is possible to erase all of the memory addresses, e. g., if the customer has misplaced a radio remote control key. Please proceed as follows:
‒ Switch on the ignition using a key.
‒ Then mechanically lock the central locking from outside using a key.
‒ Press "open/unlock" button on radio remote control key five times at 1 second intervals.
‒ Then press the "Open" remote control switch after 6 seconds to confirm this erasing procedure once again.
The central locking is now not permitted to unlock the vehicle via the radio remote control.
‒ Memory positions are erased; it must not be possible to unlock central locking system by pressing "remote opening" button.
You can now match up to four keys.
wenas
Сообщение круть-верть » Чт май 05, 2005 12:56 pm
SAY писал(а):круть-верть
А ты не пробовал сделать просто синхронизацию брелка, для этого не надо включать зажигание?
Пробовал сегодня делать синхронизацию брелка, такая же фигня, машина не реагирует.
А кодировка центрального замка такая 12864, а оригинальный номер блока управления ЦЗ 8L0862257K
Показания в первом блоке:
0000 000 0000 0000
во втором блоке:
0000 0000 001
в третьем блоке:
0 0011 0 0000
в четвертом блоке:
101 0101 0000 0000
круть-верть
Сообщение круть-верть » Чт май 05, 2005 1:05 pm
wenas писал(а):
круть-верть писал(а): ...ошибки были: ... 00956- ключ 2 выше предела адаптации. ...
обычно так кончается батарейка
батарейки новые
круть-верть
Сообщение круть-верть » Чт май 05, 2005 1:09 pm
VAG-ом делал тест исполнительных механизмов по ЦЗ, при этом из всех исполнительных механизмов работали лишь поворотники. Так наверно не должно быть? Должно же что-то ещё при этом тесте срабатывать.
круть-верть
Сообщение wenas » Чт май 05, 2005 8:20 pm
круть-верть писал(а):...в третьем блоке:
0 0011 0 0000
у тебя 2 прописанных брелка, на 1 и 2 месте. значит ты их не стер, хотя и пытался. Вывод такой: либо ты что-то не так делаешь, либо блок не видит брелков, либо косяк в проводке.
сдается мне, что у тебя накрылся концевик личинки. У тебя с личинки машина закрывает\открывает все остальные двери, ну или хотя бы слышно ли работу насоса ЦЗ в багажнике? если не получается с водительской двери, попробуй с багажника. Если не поможет, нужно по схеме смотреть цвет провода откр\закр в жгуте водительской двери и замыкать его на массу, при этом нажимать на кнопки как описано в процедуре обучения.
wenas
Сообщение круть-верть » Пт май 06, 2005 8:35 am
0 0011 0 0000
... У тебя с личинки машина закрывает\открывает все остальные двери, ну или хотя бы слышно ли работу насоса ЦЗ в багажнике?
С личинки машина закрывает и открывает все остальные двери и насос работает. Брелки не стираются. Скорее всего блок не видит брелков. Какой теперь вывод, необходим новый брелок? По какой причине мог навернуться старый брелок? Или же все-таки поможет адаптация блока по ноль каналу?
круть-верть
Сообщение wenas » Пт май 06, 2005 9:47 pm
сразу навернуться оба брелка не могут. обычно по очереди :)
читай почту
Последний раз редактировалось wenas Пт май 06, 2005 11:18 pm, всего редактировалось 1 раз.
wenas
Сообщение Vovchik_tag » Пт май 06, 2005 11:04 pm
wenas писал(а):Все дружно берем словарик и переводим...
0 0001 0 0000
‒ Wait 5 seconds.
0 0011 0 0000
Notes:
Note:
Note:
"Эльза есть у многих! А вот головняк VAG задает всем. Кто не согласен?
Vovchik_tag
Сообщение wenas » Пт май 06, 2005 11:23 pm
согласен полностью.
На любой "головняк" к Эльзе нужна еще и голова
wenas
Сообщение Vovchik_tag » Пт май 06, 2005 11:32 pm
wenas писал(а):согласен полностью.
И не корявая ЭЛЬЗА у на с их две но почему то отличаются,работа похожа на футбол на минном поле.
Vovchik_tag
Сообщение wenas » Пт май 06, 2005 11:37 pm
Эльза не корявая ? Да, есть у нее приколы, но к ним можно привыкнуть. У меня дома, та же что у всех, на работе лицензионная - ничем не отличаются. Так работаем же, не жалуемся...
wenas
Сообщение autal » Чт май 12, 2005 2:35 pm
Плохому "танцору" всегда что то мешает :D
Или за что вы девушки плохих танцоров любите? :D
autal
Сообщение kamazist » Сб ноя 10, 2007 7:15 pm
Народ, а подскажите пожайлуйста как адаптировать инфрокрасные ключи?
Проблема в следущем: в один прекрасный момент машина просто перестала сниматься со штатной сигнализации.
kamazist
Сообщение PitStop » Вс ноя 11, 2007 3:11 am
PitStop
Сообщение kamazist » Вс ноя 11, 2007 5:27 pm
но для ИК ключа АУДИ там ничего не написано, только про радио.
kamazist
