У меня по этой машине олдата. В чем упертость?
2001 Chrysler Concorde V6-2.7L VIN R Copyright © 2006, ALLDATA 8.80 Page 1
Computers and Control Systems: Testing and Inspection
P0320
SYMPTOM
P0320-NO CRANK REFERENCE SIGNAL AT PCM
WHEN MONITORED
Engine cranking.
SET CONDITION
No CKP signal is present during engine cranking, and at least 8 camshaft position sensor signals have occurred.
POSSIBLE CAUSES
- Checking intermittent CKP signal with lab
- Checking intermittent CMP signal with lab
- Checking intermittent wiring with lab scope
- Intermittent condition
- 8 volt supply circuit shorted to ground
- 8 volt supply circuit open
- 8 volt supply circuit shorted to voltage
- CKP Sensor signal circuit shorted ground
- CKP Sensor signal circuit open
- CKP Sensor signal circuit shorted to voltage
- CKP Sensor signal shorted to 8 volt supply circuit
- Sensor ground circuit open
- PCM - 8 volt supply
- PCM - CKP sensor signal
- Crankshaft position sensor
