WIS/ASRA Help
Сообщение sico21003 » Пн ноя 07, 2005 8:22 pm
Hi,
when i install WIS/ASRA,adn run PM,i get this message:
"Pictures not found.
If this problem reoccurs after program manager rastart
contact your system administrator"
and,when i run WIS.exe from C:\OPT....i get this message:
Wirkung:Weiterarbeiten evtl. nicht moglich
Ursache:Interner Datenbankfehler "11011" aufgetreten
Abhilfe"Bitte informieren Sie Ihren Systemadministrator
What i can do?I try to install so many times,but nothing!
sico21003
Сообщение autocd » Пн ноя 07, 2005 8:48 pm
9. If at start PM the message is given out, that a picture are not found and after input of the password you see the big dark blue signs on questions it is necessary to check up,
Whether all services (MPControl) work normally, but PM on a picture that it all the same swears is possible to bypass - it is necessary to find file MBCASE.INI and to correct all ways with
"\\name-of-your-server\" on "c:\opt\" after that already to establish WIS and again to correct ways in MBCASE.INI and TBWIN.INI
10. If PMADM icon not active (in PM Manager) and you can't see LanId and enter LicenseKey, do this -
Run REGEDIT.EXE
Go to HKLM\System\CurrentControlSet\Services\Tcpip\Parameters
and make register parameter - DisableDHCPMediaSense (type REG_DWORD)
it is necessary to establish in "1".
P.S. \\name-of-your-server\ - is a NAME of YOUR SERVER!! As your server refers to look in line - PM_DB_SERVER_NAME=.....
autocd
Site Admin
Сообщение sico21003 » Чт ноя 17, 2005 5:14 pm
Thanks!
it's working now!
sico21003
Сообщение AlexTDi » Вс июл 02, 2006 2:56 pm
Hello, I has the same problem with WIS/ASRA. I tried the tips out. It did not function however. Which cause could still have it? :cry:
AlexTDi
Сообщение tarianz » Вс сен 11, 2011 10:18 pm
Awesome!
tarianz
