help with ewa!!
Сообщение elgoldo25 » Пт окт 16, 2009 6:35 pm
i just installed ewa net
and when i go to favorites and then click on ewa net
it shows me this
HTTP Status 404 - / EWA-net /
type Status report
Message / EWA-net /
description The requested resource (/ EWA-net /) is not available.
Apache Tomcat/5.5.17
is there anything i can do!!
elgoldo25
Сообщение memphis » Вт окт 20, 2009 5:17 am
Did you try accessing the web address "http://localhost:9000/EWA-net" ?
memphis
Сообщение elgoldo25 » Пт окт 30, 2009 11:48 pm
yes i am trying to get from the localhost but still the same error
elgoldo25
Сообщение crank » Вс ноя 29, 2009 11:14 pm
Hi, i have a problem updating the database all goes good until the end it says:
Testing copied ROM files for database DCEX_DCEX (1 of 27) then it stops and says: The required database could not be added to the system (Error Code 50) Please check if the correct media is inserted and redable.
can anyone help me please?!!
Posted after 2 hours 42 minutes 43 seconds:
now i fixed this error but i have another problem, i installed the new database but the EPC Net database it is not starting when i pres the start button. Anyone knows something about this problem please help. Thank you.
Posted after 1 minute 31 seconds:
the picture is here
crank
